If all you want to do is export the geometry of the DOE prototype building as a gbXML file, and then import that gbXML file into DesignBuilder, then you don't need to update the IDF version. I say that because the location of surfaces hasn't changed between versions (the DOE reference buildings are based on EnergyPlus v8.0). So, you can:
