The Fatal error is rising during sizing. You should go over all of your schedules and make sure that you do have Summer and Winter Design days schedules or alternately your default day schedule, which is used for summer and winter days sizing in case there are no specific schedules, has a reasonable value.
Quick looking at your model I found out that there are not any Summer or Winter Design days schedules and Default day schedules are all set to 0. That might be your problem.
After deleting as much objects as was needed I found out that your beautiful EMS code is to blame. I went back to your model and deleted only the EMS code (and the infiltration it drived) and found out that the model is running.
It is certainly an issue you would like to open for E+ I think. Maybe @David Goldwasser could comment on that.
You can go on and delete objects from your model down to ideal load Air System and live the EMS in and then start debugging your EMS code.
