1 | initial version |
You can search example files for objects by using the "ExampleFiles-ObjectsLink.html" file in your C drive EnergyPlus example files folder. The "Coil:Cooling:DX:SingleSpeed" is in the 1ZoneDataCenterCRAC_wPumpedDXCoolingCoil.idf, 2ZoneDataCenterHVAC_wEconomizer.idf, and AirflowNetwork_MultiZone_House.idf.
2 | No.2 Revision |
You can search example files for objects by using the "ExampleFiles-ObjectsLink.html" file in your C drive EnergyPlus example files folder. The "Coil:Cooling:DX:SingleSpeed" is in the 1ZoneDataCenterCRAC_wPumpedDXCoolingCoil.idf, 2ZoneDataCenterHVAC_wEconomizer.idf, and AirflowNetwork_MultiZone_House.idf. AirflowNetwork_MultiZone_House.idf files.
