One issue that may or may not impact your decision - OS version 1.6 Sketchup plugin only works with 2015, and not previous versions. If you move to version 1.6 but don't have Sketchup2015 this may cause you problems when you try to open the model for editing in Sketchup.
Perhaps some of the OS team here can work around this issue?
One issue that may or may not impact your decision - OS version 1.6 Sketchup plugin only works with 2015, and not previous versions. If you move to OS version 1.6 but don't have Sketchup2015 Sketchup 2015, this may cause you problems when you try to open the model for editing in Sketchup.
