click to hide/show revision 1
initial version
Output:Surfaces:List,Details; will produce the surface details output which appears in the eio output file and in the Table output Initialization Summary report, subtable "HeatTransfer Surface". This lists Nominal U-Value with and without film coefficients for every surface along with other information about area, orientation, boundary conditions, etc.
Also Output:Constructions,Constructions; will produce the constructions report, also found in the eio output ad the table output Initialization Summary report, subtable "Construction CTF" which lists the thermal conductance (without films) of each construction.
