click to hide/show revision 1
initial version
answered 7 years ago
Avi's avatar
After You master the basic use of the GUI it is crucial to understand that OS is a frontend for EnergyPlus. In that sense you can use the E+ Input output reference as a guide for the different object that you might need to add to your model. As you already find out the UnmetHours forum is a great source for answers to questions you might have. My experience with learning OS has taught me that it is continuous learning while trying to implement your model. So whenever I am trying to implement new object into my model I am starting by searching the UnmetHours forum since many answers are very thorough and actually explains how to do things, then I read the relevant chapter in the E+ Input output reference. Finally, if I need I will dig into the Engineering Reference. One big step to get over is HVAC implementation in OS, since that question was asked before I will recommend on reading that post.
