Yes. This was a bug introduced when we added grid views for the zones and space type interfaces in 1.6.0. I fixed it here in response to a bug submitted by @MatthewSteen here. The fix will roll into the next release (1.7). Until then the work around is to use the "X" directly on the coil while viewing the plant. For instance if you want to remove a a water coil from a plant, navigate to that plant, locate the coil, and click on the x. If the coil is also connected to an air system, it will remain on that air system. You can then reassign the coil to a new plant using the normal methods. Note that if the coil is not assigned to an air system it will be completely removed from the model to avoid having an orphan coil hanging around.
