Alternatively, if you create an interior wall construction that is symmetrical (i.e. gypsump, insulation, gypsum), I don't believe you will get this error and you don't need to create the "reverse" construction.
Alternatively, if you create an interior wall construction that is symmetrical (i.e. gypsump, gypsum, insulation, gypsum), I don't believe you will get this error and you don't need to create the "reverse" construction.
