As it reads I am not sure you must change anything. Anyway if you would like to get reed of the warning you need to make a new construction , let's name it OPPOSITE DIVIDER WALL, and assign the same layers which form DIVIDER WALL just in opposite order. Now assign the the new construction to one of your surfaces 3 or 16 (but not both).
