In my opinion you shouldn't worry too much about that warning maybe aside of one minor issue: You might want to enter a value for Summer Design Day since it happens usually in the period that your schedule value is not 0 and for now it is assigned 0 as it reads. leaving it as it is will affect sizing. You should consider changing it if you believe that the sizing will be significantly changed if you don't.
In my opinion you shouldn't worry too much about that warning maybe aside of one minor issue: You might want to enter a value for Summer Design Day since it happens usually in the period that your schedule value is not 0 and for now it is assigned 0 as it reads. leaving Leaving it as it is will affect sizing. You should consider changing it if you believe that the sizing will be significantly changed if you don't. don't.
