The zone predicted sensible load tells you how much energy is needed to meet the thermostat set point temperature. The cooling coil sensible cooling rate tells you how much energy the coil transferred to the air, which also include fan heat and outdoor air load, if any. See if the fan heat accounts for the difference.
