Hi Siv & team! I've try to install following Juliens answer but i can't solve package dependencies, so i've decided to install from Sources last OpenStudio 2.4.0 version into Ubuntu 16.04 64 bits operating system ok :), following this steps:
If .zip: unzip file.zip -d dest_folder or if .tar.gz: tar xf file.tar.gz -C dest_folder
sudo apt-get install dpkg-dev git cmake-curses-gui cmake-gui libssl-dev libxt-dev libncurses5-dev libgl1-mesa-dev autoconf libexpat1-dev libpng12-dev libfreetype6-dev libdbus-glib-1-dev libglib2.0-dev libfontconfig1-dev libxi-dev libxrender-dev libgeographiclib-dev chrpath
Install cmake from source:
cmake --version
sudo apt-get install autotools autotools-dev automake
mkdir build
cd build
ccmake ../openstudiocore
press c to configure, and then press g to generate
make GenerateIddFactory
make GenerateIddFactoryRun
(still inside build directory)
(process run during a long time: hours)
sudo make install
OpenStudio installed from sources ok :)
To Get EnergyPlus version:
openstudio energyplus_version
To Run OpenStudioApp application:
Enjoy & Share ;) hugs, @tximikel
Hi Siv & team!
I've try to install following Juliens Julien's answer but i can't solve package dependencies, so i've decided to install from Sources last OpenStudio 2.4.0 version into Ubuntu 16.04 64 bits operating system ok :), following this steps:
cmake --version
mkdir build
cd build
sudo make install
