You probably wan tot keep the Chilled water loop, but put a District Cooling Object on the supply side as shown in this screenshot, in place of the chiller that was there to start with.
You probably wan tot want to keep the Chilled water loop, but put a District Cooling Object on the supply side as shown in this screenshot, in place of the chiller that was there to start with.
