1 | initial version |
CBECC-Com is pretty touchy when it comes to constructions assignments and surface adjacencies. I assume you are using floor multipliers and thus you need to reset the adjacency of the interior floors/ceiling being multiplied? You could instead translate the geometry into CBECC-Com, then edit the text file to change the surfaces to adiabatic, or do it within the interface. I don't think that you can translate any information but geometry into CBECC-Com.
