Construct your PV panels using the tool marked with yellow. After that double click on the PV panes and enter its efficiency. At building level go to “Generation” tab and select an inverter. In the “Generator List” select the number of generators (the number of PV surfaces that you draw in the model).
Also have a look in the DesignBuilder [help].(https://www.designbuilder.co.uk/helpv4.2/Content/AddingSolarCollectors.htm)
Also have a look in the DesignBuilder [help].(https://www.designbuilder.co.uk/helpv4.2/Content/AddingSolarCollectors.htm)help link text
At building level go to “Generation” tab and select an inverter. In the “Generator List” select the number of generators (the number of PV surfaces that you draw in the model).Also have a look in the DesignBuilder help link text
