This is obviously unsupported, but you can grab older OpenStudio installers from here, run the installer, and only select Results Viewer from the list of install options, like so:
After installing, you'll see a new application program group for that version of OpenStudio, with just Results Viewer in there.
Again, this process is not officially endorsed or supported, and comes with a couple caveats:
Also, don't forget there are other ways to skin this cat. Lots of other visualization options out there, if you're willing to delve into R or matplotlib, or to spelunk the Javascript cave(s)...
