You should be able to use EnergyManagementSystem to do this:
Exterior:FuelEquipment, request the EMS actuator dictionary (see here), check if there is indeed an actuator for this object. Worst case, I am 100% certain there is an Actuator for "Exterior:Lights" called "Electric Power" (set the End-Use Subcategory to "Water Pump" or whatever you want in order to have the right reporting in your eplustbl.htm)WaterUse:Storage's output variable Water System Storage Tank Outlet Volume Flow Rate [m3/s] (ref here)Debug, look at outputs.
I hope it helps.
Exterior:Lights here, because it has an actuator called "Electric Power", Exterior:FuelEquipment doesn't look it has one. See source: ExteriorEnergyUse.cc#L316[1] . Set the Exterior:Lights End-Use Subcategory to "Water Pump" or whatever you want in order to have the right reporting in your eplustbl.htm.Add an EMS Sensor for your flow rate, probably capturing the WaterUse:Storage's output variable Water System Storage Tank Outlet Volume Flow Rate [m3/s] (ref here)
I hope it helps.
[1] You could make sure: try with Debug, look at outputs. I hope it helps.Exterior:FuelEquipment, request the EMS actuator dictionary (see here), check if there is indeed an actuator for this object. Worst case, I am 100% certain there is an Actuator for "Exterior:Lights" called "Electric Power" (set the End-Use Subcategory to "Water Pump" object or whatever you want in order to have the right reporting in your eplustbl.htm) not.WaterUse:Storage's output variable Water System Storage Tank Outlet Volume Flow Rate [m3/s] (ref here)
Create an exterior equipment. I think you'll need to use Exterior:Lights here, because it has an actuator called "Electric Power", Exterior:FuelEquipment doesn't look it has one. See source: ExteriorEnergyUse.cc#L316[1] . Set the Exterior:Lights End-Use Subcategory to "Water Pump" or whatever you want in order to have the right reporting in your eplustbl.htm.
I hope it helps.
[1] You could make sure: try with Exterior:FuelEquipment, request the EMS actuator dictionary (see here), check if there is indeed an actuator for this object or not.
Here's a completely untested, written on the fly and manually (problems/typos expected), EMS snippet. I think the calling point should be about right, but you may have to change it.
Exterior:Lights,
RainWaterPump,
Rain Water Pump; !- End Use Subcategory
EnergyManagementSystem:Actuator,
RainWaterPump_ElecPower_Override, !- Name
RainWaterPump, !- Actuated Component Unique Name
Exterior:Lights, ! Actuated Component Type
Electric Power; ! Actuated Component Control Type
WaterUse:Storage,
RainWaterTank, !- Name
RainWaterTank_OutletFlowRate_Sensor, !Name
RainWaterTank, ! Output:Variable or Output:Meter Index Key Name
Water System Storage Tank Outlet Volume Flow Rate; ! Output:Variable or Output:Meter Name
Initialize EMS for Run , ! Name
AfterPredictorAfterHVACManagers , ! EnergyPlus Model Calling Point
Model_RainWaterPump; ! Program Name 1
Model_RainWaterPump , ! Name
IF RainWaterTank_OutletFlowRate_Sensor > 0,
! ### IMPLEMENT PUMP POWER CALC HERE, assuming 30 ft of head and 0.5 total pump eff ###
SET RainWaterPump_ElecPower_Override = RainWaterTank_OutletFlowRate_Sensor * 89,672 / 0.5,
! This IF/ELSE statement is useless here (if flow is zero, power is zero), but I wanted to show the syntax
ELSE,
SET RainWaterPump_ElecPower_Override = 0.0,
ENDIF;
| 4 | No.4 Revision |
I hope it helps.
Exterior:Lights,
RainWaterPump,
WaterUse:Storage,
!- Name
RainWaterTank, ! !- Output:Variable or Output:Meter Index Key Name
Water System Storage Tank Outlet Volume Flow Rate; ! !- Output:Variable or Output:Meter Name
Initialize EMS for Run , ! !- Name
AfterPredictorAfterHVACManagers , ! !- EnergyPlus Model Calling Point
Model_RainWaterPump; ! !- Program Name 1
ELSE,
ENDIF;
| 5 | No.5 Revision |
I hope it helps.
Exterior:Lights,
RainWaterPump,
WaterUse:Storage,
RainWaterTank_OutletFlowRate_Sensor, !- Name
RainWaterTank, !- Output:Variable or Output:Meter Index Key Name
Water System Storage Tank Outlet Volume Flow Rate; !- Output:Variable or Output:Meter Name
Initialize EMS for Run , !- Name
AfterPredictorAfterHVACManagers , !- EnergyPlus Model Calling Point
Model_RainWaterPump; !- Program Name 1
ELSE,
ENDIF;
| 6 | No.6 Revision |
I hope it helps.
Exterior:Lights,
RainWaterPump,
WaterUse:Storage,
ELSE,
ENDIF;
| 7 | No.7 Revision |
Add an EMS Sensor for your flow rate, probably capturing the WaterUse:Storage's output variable Water System Storage Tank (ref here)Outlet Inlet Volume Flow Rate [m3/s]
I hope it helps.
Exterior:Lights,
RainWaterPump,
WaterUse:Storage,
Water System Storage Tank Outlet Inlet Volume Flow Rate; !- Output:Variable or Output:Meter Name
ELSE,
ENDIF;
| 8 | No.8 Revision |
Add an EMS Sensor for your flow rate, probably capturing the WaterUse:Storage's output variable Water System Storage Tank Inlet Volume Flow Rate [m3/s] (ref here)
I hope it helps.
Exterior:Lights,
RainWaterPump,
WaterUse:Storage,
Water System Storage Tank Inlet Volume Flow Rate; !- Output:Variable or Output:Meter Name
Initialize EMS for Run , Model_RainWaterPump_CallingManager, !- Name
ELSE,
ENDIF;
