I was able to run the model you sent. I do use OS 2.3.0 as opposed to you using 2.20. I also used one of my weather files (epw). If you don't use any measures I can't see why you can't run that model. Try upgrading to OS 2.3.0 or change your weather file. If you are using measures try first to run without them. Once you will be able to run the model you will find that it fails due to activity schedules which are missing from most of your zones.
