The work around I can think of is modelling the DOAS with a variable volume fan and putting a schedule into the fan object that represents the reduction in OA at each hour for the year. You could take this information from the model already run with the DCV. I am not sure but it might just work if you had the DCV with a DOAS system with a variable volume fan
