The two options can not achieve with expression input for glaze.beacause the expression input can not make the value of keywords very with hour.But in eQuest,glazing can be switched based on outsider dry-bulb temperature, daylight illuminance, space load,intensity of sloar radiation incident on the glazing and so on .It can be set in blind/draps-switching tab.
The two options can not achieve cannot be achieved with expression input for glaze.beacause glazings because the expression input can not cannot make the value of keywords very vary with hour.But hour. But in eQuest,glazing eQuest, glazing can be switched based on outsider dry-bulb temperature, daylight illuminance, space load,intensity of sloar solar radiation incident on the glazing and so on .It on. It can be set in blind/draps-switching the blind/drapes-switching tab.
The two options cannot be achieved with expression input for glazings because the expression input cannot make the value of keywords vary with hour. hourly. But in eQuest, glazing can be switched based on outsider outside dry-bulb temperature, daylight illuminance, space load,intensity load, intensity of solar radiation incident on the glazing and so on. It can be set in the blind/drapes-switching tab.
