Just in case someone will need it, I solved the problem in this way: I wrote a python script (as suggested by Yi Zhang), included in the rvx file, with "onEachJob" : true. The script performs the following simple operations: -it opens the in.epw file in the job folder (I thought that was easier than extracting the job name, but that's up to you); -it reads the location name in the first line of the epw file; -depending on the location name it appends a different group of objects to the in.idf file.
-it 1) it opens the in.epw file in the job folder (I thought that was easier than extracting the job name, but that's up to you);
-it 2) it reads the location name in the first line of the epw file;
-depending 3) depending on the location name it appends a different group of objects to the in.idf file.
parameter tree.
