If your case, you can report at several levels, including:
Cooling Coil Total Cooling Rate
[W]Air System Total Cooling Energy
[J] (The I/O doc doesn't mention a rate one, but maybe it's still there, check your .rdd file)Plant Supply Side Cooling Demand Rate
if the Chilled Water Plant Loop only serves the zones you're interested in.A note on the "Cooling Coil Total Cooling Energy" or "Rate", since you mentioned it in your question: beware of simultaneous heating and cooling though. This will report the energy used by the coil, but if you have central heating or terminal reheat down the line, you'd effectively be providing less "actual" cooling energy.
