click to hide/show revision 1
initial version
The Export Variable to CSV" measure uses the weather file run period for the exported time series. Here is the part of the measure that does that:
# get the weather file run period (as opposed to design day run period)
ann_env_pd = nil
sqlFile.availableEnvPeriods.each do |env_pd|
  env_type = sqlFile.environmentType(env_pd)
  if env_type.is_initialized
    if env_type.get == OpenStudio::EnvironmentType.new("WeatherRunPeriod")
      ann_env_pd = env_pd
      break
    end
  end
end
The Tel Aviv weather file though contain a lot of 1999 entries appears to be of 2006. I assume that from the fact that it start on sunday January first as opposed to Friday January first as was at 1999. Here is the part from the EPW file:
DATA PERIODS,1,1,Data,Sunday,1/ 1,12/31
1999,1,1,1,60,2520______________*_____________*_*___*_*_*,7.1,6.5,96,101880,9999,9999,298,0,0,0,
Anyway as I commented above, to my best judgment you can use that data safely as far as you make sure that the day of the week is the one you selected so the right schedules will be chosen for the simulation.
ann_env_pd = nil
      ann_env_pd = env_pd
      break
    end
  end
end
The Tel Aviv weather file though contain a lot of 1999 entries appears to be of 2006. I assume that from the fact that it start on sunday January first as opposed to Friday January first as was at in 1999. Here is the part from the EPW file:
