From the Engineering Reference, the following algorithms will account for surface tilt when calculating exterior convection coefficients:
These algorithms can be used by adding a SurfaceConvectionAlgorithm:Outside object to your input file. Without this object, EnergyPlus will use the DOE-2 algorithm by default.
