EPW files are essentially rearranged TMY files, and I don't see anything in the TMY-2 data elements or TMY-3 user guide that correlate to atmospheric composition of air vs. CO2 and resulting change in convection coefficient values. As such, I would recommend adding the SurfaceProperty:ConvectionCoefficients object to your IDF, which can allow users to set interior and exterior convection coefficients using multiple options:
Note that this convection coefficients object can only be applied to a single surface.
The SurfaceProperty:OtherSideCoefficients object is another option, but it can only override exterior surface convective heat transfer coefficients and/or air temperatures.
