I think you can find the answer here and here.
In short, LegacyOS (or Euclid) is used to built geometry for E+ not for Open Studio models. And yes, there's a plug-in called OpenStudio Plug-In for Sketchup. It comes with the OpenStudio download. Here is intro tutorial. Check Preferences on whether it is enabled and disable the LegacyOS Extension.
In short, LegacyOS (or Euclid) is used to built geometry for E+ not for Open Studio models. And yes, there's a plug-in called OpenStudio Plug-In for Sketchup. It comes with the OpenStudio download. Here is are the official intro tutorialtutorials. Check If you don't see it under the Extension dropdown menu, check Preferences > Extensions on whether it is enabled and disable the LegacyOS Extension. Extension.
