Other than post processing I'm not sure how to actually do this in EP or OS, but here are some thoughts.
Snowmelt
Outdoor Pool
Use a WaterHeater:Mixed object to approximate
Construct a zone to approximate a pool with a window to allow for solar gains
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method, but for the life of me I wasn't able to actually find it there.
For reporting you may have to use/write a measure for a meter or variable output and then post process.
Snowmelt
Outdoor Pool
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method, but for the life of me I wasn't able to actually find it there.it.
Snowmelt
Outdoor Pool
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method, but for the life of me method. That UX on that site is atrocious IMO so I wasn't able to actually find it.the attachment there, but hopefully others will have better luck.
| 4 | No.4 Revision |
Snowmelt
Outdoor Pool
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method. That UX UI on that site is atrocious IMO so I wasn't able to actually find the attachment there, but hopefully others will have better luck.
| 5 | No.5 Revision |
Snowmelt
Outdoor Pool
Use a WaterHeater:Mixed object to approximateapproximate the pool
@Jim Dirkes posted a spreadsheet calculator on the EnergyPlus Support Group based on the Mirza Shah method. That The UI on that site is atrocious IMO so I wasn't able to actually find the attachment there, but hopefully others will have better luck.
Let us know what you come up with.
