I solved the warning error of "CheckWarmupConvergence: Loads Initialization, Zone="Zone_1" did not converge after 25 warmup days" by changing the "Loads Convergence Tolerance Value" from 0.04 to 0.07 under the object Building. The result values at the .csv file are very similar with before (when I had the warning error).
