I have same problem and already have tried all the suggestions here but no success! appreciate if somebody tell us what is a successful option to save and open a OS project created with Sketchup and OS plug in.Thank you. p.s. I have saved my project in sketchup with name.osm; also I tried name.skp and again same problem
I have had the same problem question and already have tried all found this best answer from somebody else in this forum; I copy-paste it here:
(in case anybody else with the suggestions here but no success! appreciate if somebody tell us what same question comes here)
The SketchUp file (.skp) is a successful option to not used in any way by OpenStudio. You should not use SketchUp's File/save or load options. All saves and loads should use the OpenStudio toolbar save and open a OS project created with Sketchup and OS plug in.Thank you.
p.s. I have saved my project in sketchup with name.osm; also I tried name.skp and again same problemload buttons. The .osm file is the only thing that matters.
