@LSurf, of course there is: EnergyPlus is open-source! You can download the source from GitHub (https://github.com/NREL/EnergyPlus/releases/), compile it yourself (in DEBUG mode), and then run it within a development/debugging environment like MS VisualStudio. Are you game? If not, you can send someone who has a debugging setup (e.g., me) your file and we can tell you what is going on.
