Places where you can search for free weather files are for example:
  • https://energyplus.net/weather
  • http://climate.onebuilding.org/
  • Files of the EnergyPlus Support Group (yahoo): https://groups.yahoo.com/neo/groups/EnergyPlus_Support/files
There are two Meteonorm files on the EnergyPlus Support files here.
  • MLT_Marsaxlokk_MN6.zip
  • MLT_Luqa-Qrendi_MN6.zip
A few general recommendations:
  • Please always search for existing questions, for example:
    • https://unmethours.com/question/21291/what-sources-are-available-for-typical-weather-data-beyond-energyplusnet/
    • https://unmethours.com/question/1/what-are-the-available-sources-for-historical-weather-data/
  • in general neither is UnmetHours nor the EnergyPlus support group a good place to ask for random weather files. Try to find them yourself, and if you can't, then order them from a commercial website (see the two questions above).
  • Cross posting between UnmetHours and EnergyPlus Support Group is generally bad practice. Pick one. Or at least wait a few days to see if you get a response from one of the two before you consider double posting.
click to hide/show revision 2
No.2 Revision
There is a MeteonormReadme.txt that you must read for limitations about Meteonorm files if you aren't familiar with it.
click to hide/show revision 3
No.3 Revision
click to hide/show revision 4
No.4 Revision
