While Dview does bring a ton of new features to the table regarding EnergyPlus output data viewing and manipulation, Dview lacks the ability to view illuminance map data. It is unfortunate that Results Viewer was dropped from OpenStudio/EnergyPlus; as far as I know, you can still use Results Viewer from previous E+ versions to view the eplusout and radout.sql files generated by OpenStudio 2.3 though.
