Your model has a default construction set, but it is referenced by the spaces, not from the building object. So when the code looks for default_construction_set.sources it is not finding any source that can cast to_Building.
If you don't want to change the osm, you can extend that code as implied by the comment #add SpaceType, BuildingSotry, and Space if statements, like:
space_source = construction_set_source.to_Space
if not space_source.empty?
space_source = space_source.get
space_source.setDefaultConstructionSet(new_default_construction_set)
next
end
Your model has a default construction set, but it is referenced by the spaces, not from the building object. So when the code looks for default_construction_set.sources it is not finding any source source that can cast to_Building.
next
end
If you don't want to change the osm, you can extend that code as implied by the comment #add SpaceType, , like:BuildingSotry, BuildingStory, and Space if statements
next
end
