I've attached screenshots of E+ report. Actually, I am trying to understand how detailed HVAC works, therefore I've started from very simple system and once I've got the hang of that, I will gradually be making the model more complicated. Sorry, for a mistake - airflow should be 12.5 m3/s everywhere. I am going to check my fresh air settings in the model.
I finally got to the bottom of this problem. The solution was to set the 'Outside air definition method' to 'By zone' and set a desired ac/h.
