I suggest you check the Release Notes of E+ 8.8.0.
Linux (Ubuntu 14.04 and compatible) 64 bit versions; (RHEL-compatible versions may be available via Helpdesk)
The helpdesk is located at http://energyplus.helpserve.com/. You can subscribe, then Submit a Ticket asking for your binary.
Otherwise you can always try to compile the source code yourself, if that's something you are familiar with.
