We have a meta_measure.rb helper script you may be interested in. It's not really documented, but the script will:
update_args_hash method).run_measure method).workflow_json argument to above method). If not provided, it will simply run the measures in the order that you added measures/arguments.osw_out argument to above method).show_measure_calls to above method).Here is a simple example of it being used.
update_args_hash method).run_measure workflow_json argument to above method). If not provided, it will simply run the measures in the order that you added measures/arguments.osw_out argument to above method).show_measure_calls to above method).Here is a simple example of it being used.
update_args_hash run_measure workflow_json argument to above method). If not provided, it will simply run the measures in the order that you added measures/arguments.osw_out argument to above method).show_measure_calls to above method).Here is a simple example of it being used.
| 4 | No.4 Revision |
update_args_hash method once for each measure).run_measure method).workflow_json argument to above method). If not provided, it will simply run the measures in the order that you added measures/arguments.osw_out argument to above method).show_measure_calls argument to above method).Here is a simple example of it being used.
| 5 | No.5 Revision |
| 6 | No.6 Revision |
update_args_hash method once for each measure).run_measureapply_measures method).workflow_json argument to above method). If not provided, it will simply run the measures in the order that you added measures/arguments.osw_out argument to above method).show_measure_calls argument to above method).Here is a simple example of it being used.
