Yes, there is a way to call a measure, or multiple measures from inside another measure, but that does take a little but of setup. You can borrow the code from measure tests, and place it in the run section of a measure. Do this multiple times to run more than one measure. File management of measures can create issues.
Another idea you might consider is to create a new OSM file, and then place all the measure you want to run in the workflow of measures tab. Now quit OpenStudio. You can now run 'workflow.osw' using the CLI to quickly run all the measure on any OSM file. Here is link to CLI documentation
