You should take a look at the Example Files that are in the E+ installation folder, you will find many good examples as a starting point. There are two .html files that will help you find the files of interest.
For example, 1ZoneDataCenterCRAC_wPumpedDXCoolingCoil.idf might be a good starting point if you happen to have CRACs as cooling systems. 2ZoneDataCenterHVAC_wEconomizer.idf which relies on Single-Zone AirLoopHVAC objects, 5ZoneSupRetPlenRAB.idf will show you how to set up an Under Floor Air Disitribution (UFAD), etc.
