I could be wrong, but I don't think steam systems are supported in OS yet even though some of the fields are exposed. You may have to model it as a water system instead or write an EnergyPlus measure.
I could be wrong, but I don't think I'm not sure steam systems are supported in OS yet even though some of the fields are exposed. Have you been able to model them previously? You may have to model it as a water system instead or write an EnergyPlus measure.
