I don't know if this works, but if you download the program elements (open-source). Here your have a link: http://bigladdersoftware.com/projects/elements/
With this program you can open epw. files. Maybe the program automatically devides the radiation into horizontal and normal radiation. It is worth a try.
![]() | 2 | No.2 Revision |
I don't know if this works, works also for you, but if you download the program elements (open-source). Here your have a link: http://bigladdersoftware.com/projects/elements/
With this program you can open epw. files. Maybe With the program automatically devides following link you can see the radiation into horizontal and normal radiation. It is worth a try. steps you have to take in order to get your results: http://bigladdersoftware.com/projects/elements/docs/user-guide/tutorial-create-from-scratch.html
![]() | 3 | No.3 Revision |
I don't know if this works also for you, but if you download the program elements (open-source). Here your have a link: http://bigladdersoftware.com/projects/elements/
With this program you can open epw. files. With the following link you can see the steps you have to take in order to get your results: http://bigladdersoftware.com/projects/elements/docs/user-guide/tutorial-create-from-scratch.html
This link might also help when you use Elements: https://unmethours.com/question/11948/elements-normal-solar-versus-direct-normal-radiation/
