The Sketchup Plugin for 1.6.0 only works with Sketchup 2015.
I suspect that perhaps you are using a version of Sketchup from before 2015, which is likely the source of your problem.
I suspect that perhaps you are using a version of Sketchup from before 2015, which is likely the source of your problem. This would be why your version of Sketchup is loading an older version of the OpenStudio plugin.
