In answer to the 'without default ground temperature' aspect of your question, see here Sample Code for Adding Ground Temperatures.
If your simulation crashes, you might find something informative in the .stderr, stdout files. I did a quick test of the AedgK12SlaAndBasement measure (which is dated from 2014) and my simulation failed. The error message points to line 326 where OS::Runmanager is called. The measure may be failing due to the deprecation of RunManager RunManager is deprecated
release notes state: "...The API for OpenStudio Model and other core namespaces was mostly preserved during the OpenStudio 2.1.0 conversion. However, the RunManager, Analysis, Project, and AnalysisDriver namespaces were completely removed. The CLI and OSW format replace the functionality of RunManager."
