I'm not sure whether you want to change input variables or do runtime control. For input variables you can wrap EnergyPlus with a scripting language like Python, Ruby, etc, and using that to edit the input file, launch a run, and handle the results. The syntax I use is inspired by jEPlus where they denote values to be edited like @@variablename@@
I've posted a Python snippet for doing the IDF editing before. The link's here.
Launching a run is simple:
import subprocess
subprocess.call('"%s" "%s" "%s"' % ([path to RunEPlus.bat], [path to IDF or IMF], [path to EPW]))
And then finally for handling the results I highly recommend using pandas as a really good time series data processing library.
If you're talking about changing values during runtime you'll need to look into EMS.
import subprocess
If you're talking about changing values during runtime you'll need to look into EMS or BCVTB.
