Have you looked at the documentation for Design Alternatives for a manual analysis? I think that is what you are looking for. The design alternatives can be run locally or on Amazon EC2.
Update: (calling earlier measure argument values from within a measure) @Alex Bennett, I don't think this will fit in comment so I updated my answer.
The following method will loop through all upstream measure arguments, stopping at the first argument matching the requested name. It will then return the value of that measure.
def self.check_upstream_measure_for_arg(runner,arg_name)
# 2.x methods (currently setup for measure display name but snake_case arg names)
arg_name_value = {}
runner.workflow.workflowSteps.each do |step|
if step.to_MeasureStep.is_initialized
measure_step = step.to_MeasureStep.get
measure_name = measure_step.measureDirName
if measure_step.name.is_initialized
measure_name = measure_step.name.get # this is instance name in PAT
end
if measure_step.result.is_initialized
result = measure_step.result.get
result.stepValues.each do |arg|
name = arg.name
value = arg.valueAsVariant.to_s
if name == arg_name
arg_name_value[:value] = value
arg_name_value[:measure_name] = measure_name
return arg_name_value # stop after find first one
end
end
else
#puts "No result for #{measure_name}"
end
else
#puts "This step is not a measure"
end
end
end
One example is that two or more measures have an argument or a specific 90.1 standards. In our measures this measure is often named "template". I would call this code in each measure to override the user entered value. with the value from the first instance of "template" as a measure argument. So if measures "A,C,X and Y" all called for "template" I would setup "template" as a variable for "A" and add code to "C,X, and Y" to use whatever was used for "A". This code is shown below.
# look at upstream measure for 'template' argument
# todo - in future make template in this measure an optional argument and only override value when it is not initialized. There may be valid use cases for using different template values in different measures within the same workflow.
template_value_from_osw = OsLib_HelperMethods.check_upstream_measure_for_arg(runner, 'template')
if template_value_from_osw.size > 0
runner.registerInfo("Replacing argument named 'template' from current measure with a value of #{template_value_from_osw[:value]} from #{template_value_from_osw[:measure_name]}.")
args['template'] = template_value_from_osw[:value]
end
Another possible use case, if Measure "C" has not been run, or has not been run with specific measure arguments, then don't run measures "X,Y, and Z". While you can't really skip them on the fly, you can add a test at the very beginning of the run section, with a return true within the if statement if the test is true.
For some tests, you wouldn't even need upstream measures. You can directly check the model for building type, size, number of stories, climate zone etc. This gives you a lot of control to minimize variables, and use embedded logic to control the rest of the workflow. This would be good topic for advanced measure writing class.
# 2.x methods (currently not setup for measure display name but for snake_case arg names)
arg_name_value = {}
end
name = arg.name
if name == arg_name
end
end
else
end
else
end
end
end
end
