I believe you may be getting tangled up in the meaning of nominal capacity. As discussed in this related question nominal capacity is what happens at standard rating conditions. It is not the capacity of the coil at the conditions you are running at. Secondly, the COP that you specify as an input to the cooling coil, is at rated conditions, it is not a constant value.
