You can request Zone Mean Radiant Temperature by adding an Output:Variable.
As far as modeling a semi-open space, you'll have to model infiltration properly, perhaps using Airflow Network if you need that complexity.
As far as modeling a semi-open space, you'll have to model infiltration properly, perhaps using Airflow Network if you need that complexity.complexity.
There have been a few questions that are on a similar topic, including Modelling vents in EnergyPlus
