Place your weather file next to your osm, and run this OSW:
"seed_file": "Model (IECC 2015 & ASHRAE 90-1-2013 - RTU-FPB).osm",
"weather_file": "USA_TX_Corpus.Christi.NAS.722515_TMY3.epw",
"steps": [
Place You can try placing your weather file next to your osm, .osm, and run this OSW:
"steps": [
This will overwrite the weather file actually used by the model, so beware.
You can try placing your weather file next to your .osm, and run this OSW:
"steps": [
| 4 | No.4 Revision |
"steps": [
| 5 | No.5 Revision |
"steps": [ ]
Test 1: provide a file that is in the same folder:
I created an empty.osm model, didn't not set a weather file. (I opened a terminal, loaded ruby bindings, and just did model = OpenStudio::Model::Model.new then model.save('empty.osm').
I put a weather file next to it in the same folder, USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw.
Created a test.osw:
"seed_file": "empty.osm",
"weather_file": "USA_IL_Chicago-OHare.Intl.AP.725300_TMY3.epw",
Here's the content of my folder:
$ ls
empty.osm
test.osw
Then $ openstudio run -w test.osw
Worked perfectly.
As you can see, stepsisn't required (it works with it though).
Test 2: provide a file_paths argument
Only changed the OSW:
"file_paths": ["/Applications/EnergyPlus-8-7-0/WeatherData/"],
"weather_file": "USA_VA_Sterling-Washington.Dulles.Intl.AP.724030_TMY3.epw",
The Sterling weather file is NOT in the current directory, but it is in the directory I pointed for "file_paths".
Worked perfectly too.
Note that you can also have relative paths (compared to root, if root isn't set, that's the directory containing the osw. See the JSON Schema
Test 3: set the weather file in the OSM itself.
I opened empty.osm and set the weather file to another EPW (Tampa).
[4] TestOSW(main)> puts model.weatherFile.get
OS:WeatherFile,
{9b78b8e8-0d6e-4674-b157-cd24f9a09e21}, !- Handle
Tampa International Ap, !- City
FL, !- State Province Region
USA, !- Country
TMY3, !- Data Source
722110, !- WMO Number
27.97, !- Latitude {deg}
-82.53, !- Longitude {deg}
-5, !- Time Zone {hr}
6, !- Elevation {m}
file:USA_FL_Tampa.Intl.AP.722110_TMY3.epw, !- Url
847DE5F2; !- Checksum
The weather file, as expected, got copied to ./empty/files/USA_FL_Tampa.Intl.AP.722110_TMY3.epw.
Changed OSW to:
"steps": []
=> Did not work.:
[09:44:54.432491 ERROR] Found error in state 'initialization' with message ["Weather file 'USA_FL_Tampa.Intl.AP.722110_TMY3.epw' specified but cannot be found::/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/jobs/run_initialization.rb:158:in `perform'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:261:in `step'\n:/ruby/2.2.0/gems/openstudio-workflow-1.3.1/lib/openstudio/workflow/run.rb:210:in `run'\n:/openstudio_cli.rb:804:in `execute'\n:/openstudio_cli.rb:620:in `execute'\n:/openstudio_cli.rb:1517:in `<main>'\neval:85:in `eval'\neval:85:in `require_embedded_absolute'\neval:70:in `block in require'\neval:64:in `each'\neval:64:in `require'\neval:2:in `<main>'"]}
I think it should work, so I'd consider that a bug.
