1 | initial version |
In the SketchUp Plugin is the shading surface facing the sun light purple or dark purple? The darker color is the outward normal for the surface and the side that PV panels are on.
2 | No.2 Revision |
If if it is light purple, Double click on the shading surface group then click on surface so it is selected. Then right click and choose 'reverse face'.
