click to hide/show revision 1
initial version
There is no known issue with this type of equipment. You have not said how you described this system (with an interface, or with HVACTemplate, or detailed unitary system, or ???). If you are working in native EnergyPlus, I would recommend that you use HVACTemplate:Zone:Unitary and HVACTemplate:System:Unitary and it should work just fine.
