You could do this with the openstudio CLI. There are methods to import gbXML and an existing Measure to generate 3D geometry HTML. You'd need to write a small Measure to call the import method then you could string together those two Measures in an OpenStudio Workflow and run rather compactly with the CLI.
You could do this with the openstudio CLI. OpenStudio CLI. There are methods to import gbXML and an existing Measure to generate 3D geometry HTML. HTML. You'd need to write a small Measure to call the import method then you could string together those two Measures in an OpenStudio Workflow and run rather compactly with the CLI.
You could do this with the OpenStudio CLI. There are methods to import gbXML gbXML and an existing Measure to generate 3D geometry HTML. You'd need to write a small Measure to call the import method then you could string together those two Measures in an OpenStudio Workflow and run rather compactly with the CLI.
